First time, I'm trying to change my rear brake rotors and pads.
According to shop manual, there's a bolt to loosen and flip up the caliper, but I notice it's really rusted. However, the two caliper mounting bolts are "like new". Is there a trick that you just remove the entire caliper (like you're going to change the rotor) which allows you to change the pads?
I guess I'm asking, just remove two caliper bolts and forget about the lower slider bolt?
quick answer requested
cause .....
