I have a 2009 Odyssey EX with 155,000 miles on it. It has the original Alternator. Battery is getting close to 4 years old, with 36,000 miles on it.
About a month ago I was driving the van and the "Charging System Indicator" light came on about a half mile from my destination. So I turned off all the accessories I could (radio, lights, climate Control..) and drove to the restaurant. When I was done eating, I had my friend jump start my van in order to keep as much charge on the battery as possible. When I turned the van on, I heard a different noise coming from the van around the serpentine belt. I figured the noise was coming from my alternator.
I drove the van from the restaurant to the nearest Auto Zone, which was 2-3 miles away. During the drive, the Charging System Indicator turned off. I had Autozone check the alternator and battery, and they said both of them were fine.
I drove home and checked the voltage on the battery. It was around 12.6 when the car was off and 13-14 something when the car was on (I don't remember the exact voltage). For the next week, I would check the voltage before I left and when I got home to make sure the battery was charging. I would check both running and when it was off. Each time I checked it looked fine.
For about a month, the battery charging indicator didn't come on at all. Then one day my wife started the van at work and heard a "noise" coming from the engine. She looked down and the indicator was on. She said the noise went away about 20 seconds later and the indicator had gone off again.
The indicator has been off now for about a week. The issue has only happened twice, both times the van was away from home. I haven't been able to really try to diagnose the issue since I haven't seen it while at home. My wife is the main driver of the van, and she only drives 2 miles to work. I drove it on Friday for probably 15 miles without issue.
I don't want to drive the van too far from home since I don't want to be left stranded. But I want to fix the issue. Should I just replace the alternator and hope that it is the problem? Or are there other things that could cause this issue? I guessing that due to the noise my wife and I both heard, it is not a grounding or cable connection issue.
I'll read here that I should only use a Denso Alternator. Both RockAuto and Summit racing have one in stock (Remanufactured) for about the same price. Is there a preference between one or the other? The advantage of Summit Racing for me is that there is one within driving distance (45 minutes) if for some reason I need to drive there, but I would have it shipped.
