Hi All -
I have a 2017 EXL. I installed the infamous VCM Muzzler II from Verbatium about 3 months ago. It's been running fine on the standard, pre-installed resistor. I've only had a couple occurrences where the ECO kicked on. Today my wife told me her CEL light kicked on. I haven't had time to run to Auto-Zone to have the codes read, but I guess my three questions are: (1) Does the VCM Muzzler cause the engine to throw codes? (2) If so, what are the common codes seen with the muzzler installed? The temperature has been fairly consistent. (3) Do many need to change out the pre-installed resistor as it gets colder outside? I thought you only need to increase OHM's in hotter climates.
Thanks,
Jeff
Thanks,
Jeff
