Which 'performance' chip are you referring to?korter said:anyone ever try the performance chip, and have it de-tuned/programmed for mpg? seems like this should be good for a couple mpg.
Buffalo4
If you put it on a dyno and could see the air fuel ratio, there may be some room to lean it out safetly. Typically the stock maps run rich to be safe. Would require a dyno session though. That would probably set you back 300-500. The fuel savings would never offset this cost.mjody said:Maybe on a diesel. Explain how on an Ody it would improve. You would need to lean out the mixture, which is bad.![]()
WW I really want to come and visit your Ody. I'm sure with a new O2 sensor and some intake manifold service you'd start getting 14 mpg city. I used to be in the same boat with you until I fixed all the defects causing me bad mpg.wild willy said:Would it be possible for me to get 10....maybe even 11mpg with a chip![]()
If you come, you have to take it with youpvandegriff said:WW I really want to come and visit your Ody. I'm sure with a new O2 sensor and some intake manifold service you'd start getting 14 mpg city. I used to be in the same boat with you until I fixed all the defects causing me bad mpg.
A freebie? Dude, I need your address.wild willy said:If you come, you have to take it with you![]()
Ummm, proof? Stock mapping is close to stochio to pass federal emissions testing. Rich is harmful, burns out cats and poor fuel economy.DavidGSR said:Typically the stock maps run rich to be safe.
