1 - 2 of 2 Posts
Does the A/C compressor normally cycle when using heat? I've got the climate control set at 72 degrees and the 03 Ody compressor kicks in when it's 40 degrees outside. Also, the vehicle tries to surge forward a bit with the brakes applied when this happens. I've searched the threads for this but could not find any information.
Administrator
In AUTO mode yes. The system runs both heat and a/c to remove moisture and get your set temp. That's normal.
1 - 2 of 2 Posts
