I have a 2003 odyssey EX with 171,000 miles and am getting a loud clunk when shifting into reverse (only when cold). I have read that this is likely due to a bad engine mount. I have checked all 4 mounts and they look good. The rubber seems fine and no unusual vibration. There was no unusual movement or noises when reving the engine (low rev while in Drive and foot on brake done by assistant). When doing that the engine rotated side-to-side a little and the front hydraulic mount compressed down less than 1/8 inch and came right back up. Is there anything else I should check?
Passenger side mount was replaced at 100,000 miles. Also, can the hydraulic mount look fine installed but be bad? Can't see the inside of that mount.
