Hi Everybody.
I have an '03 Odyssey, 150K. When city driving there is a clunking sensastion in the steering wheel on rough roads. At highway speed there is a vibration only when you let off the gas (you can kind of feel a weight shifting forward). Slight play in the front driver side wheel when hands are are 3 and 9;no play when grasped at 12 and 6. I replaced struts, sway bar links and caliper pins, balance and alignment. Fairly new Michelin Symmetry tires and wear appears normal. What should I check next?
Thanks. Rob.
Thanks. Rob.
