1 - 2 of 2 Posts
hi i have a 2003 honda odyssey 3.5 L have no lights on but the maintenance required light flashes but only when start my van. so we scanned it and it came up as 31-02 engine retard command (PFINH) signal failure. trying to figure out what it is but cant find any information anywhere online
This post is not "News", this belongs in the 2nd Generation section.
That being said, the Maintenance Required light is to remind you to change the oil! You can get the Owners Manual that describes this for your 2003 in the 2nd Generation section. Flashing at start- almost time to change the oil. It will soon glow solid all the time. Reset info is in the Owners Manual.
Post there and you should get better info for your code. And what scanner did you use to get that code?
1 - 2 of 2 Posts
