I have a 2007 Honda Odyssey and I want to use this cold air intake. I've had it on the van for about 2 years, and it's been a bit of a problem since there's a rubber hose that's supposed to connect to the big, cumbersome air intake/breather box. This hose has a vacuum line attached to it, so I can't connect this directly to the manifold. I tried 3M weather strip adhesive and that didn't work. I did have this supported the best I could with zip ties so it wouldn't weigh down on the rubber intake hose. That failed last week and a chunk of the hose got stuck in the throttle body and it was a costly repair. The metal tube that I purchased didn't exactly work with the mass air flow sensor, so I had to modify it and zip tie that down and pack the edges. It's an aftermarket "Jet" MAFS.
The question I have is does anyone make a connector so that I can use the cold air intake along with the MAFS and not have any problems? This setup really makes a difference in horsepower. I've looked online trying to find the right products, but the problem appears to be the rubber hose with a vacuum line, as it can't take the weight of the air filter weighing down on it. I got the original air intake system put back in (The damn hose was $50) and I like my vans to perform better than factory.
