1 - 2 of 2 Posts
Hello,
I am in process of cleaning/checking 5AT solenoid from 2002 Ody. I could not remove front top shift solenoid even after removing starter motor. How did you do it? Solenoid touched the transmission housing after half -coming out.
One thing I found out so far was front bottom shift solenoid is delayed by 1 second after applying 12 volt. Definitely I will replace it. I do not have any OBD2 code. Transmission slipped 2-4 times during local trip at 25 mph. Once this happened, i had to coast/stop to try to engage gear.
Any suggestion is appreciated.
Thank you
Suggestion to get shop manual if you don't already have one. I'm new to Honda but have done major work on other cars just taking my time and doing with a book as reference!
1 - 2 of 2 Posts
