1999 Odyssey
Replacing Timing Belt.
I first had the Cam sprockets aligned and marked TDC #1.
Then went on and removed Crank Pully (10ft breaker bar) to make markings on it.
To cut to the chase (leave out details of how I got here):
With the key inadvertently removed; I moved the crankshaft independent of the Timing Belt Crank sprocket.
Attempt to realign:
Old timing belt is still in place.
I moved things so the Cam Sprockets and my belt marks are back to TDC #1. I now have a hold on the Cam sprockets to prevent them from moving.
I'm going to try moving the crank so I can get all three key slots aligned: Crank Pully, Crankshaft and Timing Belt Sprocket. My thinking is to get them realigned while the old belt is on so there are less independent moving parts and I don't get into deeper trouble.
Or is it best to now remove the Timing Belt first? Then get the Cams and Cranks aligned? Then install the new belt?
Or is there an entirely better/proper way to realign the whole shooting match base on the current state of affairs?
--brad
Attempt to realign:
--brad
