quick info:
Standard Thermostat
Lift Height: Above 10.0 mm (0.394 in)
Starts Opening: 169-176 °F (76-80 °C)
Fully Open: 194 °F(90°C)
Thermostat Replacement
1. Drain the engine coolant (see page 10-6).
2. Remove the intake air duct (see step 2 on page 9-6).
3. Remove the thermostat cover, then remove the thermostat
4. Install the new thermostat with a new rubber seal, then install the thermostat cover.
5. Install the intake air duct (see step 6 on page 9-8).
6. Refill the radiator with engine coolant, and bleed the air from the cooling system (see page 10-6).
7. Clean up any spilled engine coolant
Standard Thermostat
