I'm copying the following post from edmunds.com Odyssey Problems VII forum regarding "proper" installation of EX crossbar to eliminate wind noise:
495 of 501 Crossbar Wind Noise 2001 EX by edm85 Feb 28, 2001 (02:08 pm)
I just installed crossbars on my 2001 ex. I followed the instructions exactly, placing them at the marks on the side rail. I now have wind noise to the extent that if I can't eliminate it I will remove the crossbars and install them only when I need them.
Any one out there have this problem and how do you eliminate it or reduce it, short of removing them?
Thanks,
ED
#497 of 501 edm85, wind noise by auburn63 Feb 28, 2001 (06:41 pm)
If the cross bars are installed in the wrong direction with the trailing edge forward instead of towards the rear then they will make a loud noise.If you look at them they are alot like a wing on a plane and need to be installed with the more rounded side forward.Take a close look at them and see if you see what I am talking about. I know there is another distinction but I can't remember it right now. I will post again when my senior moment passes....
#499 of 501 #497 Cross bar wind noise by edm85 Mar 01, 2001 (01:01 pm)
Thanks for the info on getting the crossbar nose in the right direction. I turned them around and the wind noise is gone.
Don't know why the instructions don't tell you to do that.
Thanks again.
Anybody else tried this on their Odyssey??
MarioB
01 EX DEP
Thanks,
ED
Thanks again.
MarioB
01 EX DEP
