Hi all, I have a 2004 Odyessy and discovered after the purchase on the way home that the cruise control does not work. Its just one of those little things you forget to check and just assume it works. In reading the posts here I have been checking fuses and connections, in doing that I discovered a 2 wire harness on the same cluster that goes to the brake switch unplugged, it has a lt blue and black wire. I wanted to see if anyone knew or could look on their's to see where it plugs in, before I go replacing things. It might be the problem or it might just go to something completely different. Also just to explain further the issue, the cruise on/off switch on the dash will light up but the cruise will not set or light up on the cluster. thanks in advance
