1 - 6 of 6 Posts
Is it just the gauge light that illuminates the gauges or all the individual lights in the gauge cluster? Which ones are out. Does your audio unit work?
Thanks for responding!
Over a year ago, my toddler put coins in the CD player. :( So the audio quick working shortly after. Then the interior light quit working. Now my WHOLE dash is not lighting up with the exception of the mileage and what gear it is in.
And last night I was pulled over due to having no tail lights.
Help! Is all this happening because the coins? Or is my car crazy?
Thanks again.
Hopefully you have a 1999-2004 Odyssey and can check these fuses by priority:
Passenger's Under-Dash Fuse/Relay Box
Fuse #11 (10A)
Fuse #10 (15A)
Fuse #9 (15A)
Driver's Under-Dash Fuse/Relay Box
Fuse #9 (10A)
My $ is on the first fuse listed above being bad. You may need to get rid of the coins in the audio unit as it may keep blowing fuses.
Remove from dash and shake out coins is the only way I believe. Search here for "audio unit removal" or similar terms...
1 - 6 of 6 Posts
