I want to change the "Go Home" address. The book says to access previous destinations and it will change to let me delete. I could not find anywhere to delete.
I don't know about deleting anything, but you can edit the Home 1 or Home 2 address by following the Nav manual instructions, starting with page 90 to select which Home address, then continue on page 94 to edit it.
I thought I posted this yesterday but could not find even with a search.
I want to change the address for "GO Home". Editing the address is not an option so I thought to delete and reprogram. I did not use a PIN.
Page 96...The book says:
Previous Destinations
1. Select this option and the display changes to:
(Graphic shows "select a destination to delete)
2 Scroll through the list to find the address you want to delete.
3. Select the address to delete by saying the line number or by using the Interface dial.
I do not find that menu to delete. Can anyone advise?
You did post this. It was moved to the right place which is the dedicated forum for Audio/video/NAV systems. You can easily find it by searching for your own posts.
Thank you. I had used the index and gone straight to deleting when I needed to start with the personal info area. I have it now. Thank you. Sorry for being so ignorant to post in the wrong area. I knew my way around my 2005 Odyssey but this one is different. I do like the dial instead of the touch screen.
