I'm snapped a bunch of pictures today when I did my VCM disable project on our 2005 Odyssey EX-L. MANY, many thanks to kgardonia, verbatim, thenaaks, etc....all the the users that actually figured this out. I take no credit for figuring it out...I just wanted to show what I did (with pictures) to disable VCM on my 2005. If you are interested in disabling it on the newer 2008-on models, you can buy a nice pre-made piece from the user verbatim that is literally plug and play. If I had a newer van, I would 100% would have gone that route.
Here's what you need:
-Male and female terminal disconnect's. I prefer the "fully insulated" ones that have plastic covering the entire connector
-1/4" heatshrink
-some 16awg wire
-83(ish) ohm's worth of high quality metal film 1% tolerance resistors. 0.5watt or 1watt. I used 1 watt, which is overkill, but they're good resistors. I bought mine from the user communications_lab on eBay. Great seller.
-red butt connectors (the smallest ones)
-IMPORTANT: You need some way to monitor actual engine temperature from the OBDII. I used a ScanGaugeII, because I already have one. I would recommend getting one, but if you get it JUST for this...it's makes the project a bit pricey. They are very useful overall....and if you fancy yourself a do-it-yourself car guy....you should have one.
Pictures of the stuff:
1) Drive the van with your OBDII monitoring tool hooked up, and watch the temp gauge and the OBDII reported coolant temperature. You'll notice on a test drive that your ECO light won't come on until the coolant passes 170(ish). This is the entire premise of this fix: make the ECU think that the engine isn't warm enough to engage VCM.
Here's my van, fully warm, before the disable wiring
2) Pop the hood and let it cool off a bit while you head to the workbench and make your wiring.
3) Using butt connectors, connect your resistors and your terminal disconnects. Since the resistors have small stiff wires on them, I didn't trim them at all for the butt connectors..just passed them all the way through. More metal to crimp, better connection. I added a length of 16 AWG wire because the terminal/butt connector/resistor combo is long and stiff and I didn't want to have to bend it at all when it was installed. The wire gives you a nice flexible section to get it arranged when you actually install it. Use heatshrink before you put that last terminal disconnect on. Also, I forgot to put the terminal connectors on in a way that would allow me to take the wiring out, and plug the factory wire straight back together....now if I take mine out, I'm left with two female ends. Oops. I won't ever be taking it out.
Finished product
4) Unplug all three connectors that are the same wiring harness trunk, to give you plenty of room to work.
Continued in next post......
-1/4" heatshrink
-some 16awg wire
Finished product
