DIY: 2007 Honda Odyssey License Bulb
- License Bulb is somehow omitted in the owner’s manual.
- There is a separate thread about LED bulb, search if you wish to use LED bulb.
- Bulb is 2825 type at local autoparts store; or Honda 33301-SA0-741. About $1.50/each at Honda dealer. I bought a few extra bulbs and store them in the glovebox (it is cheap and not worth the time and gasoline cost to run back and forth to dealer should I need more bulbs later).
- The Lense Cover has a “Clear” and “Black” part. “Clear” part has a smaller tab and faces the rear of the car. “Black” part has a slightly larger tab.
- Use a small FLAT Blade screw driver wrapped in cloth and gently pry it out. I pry on the Black larger tab side. Do not use excessive force. Just gentle prying.
- When re-installing Lense Cover, I install the Larger Tab side first and just snap the other side in.
Hope this helps.
Hope this helps.
