Hello, good evening everyone.
I would appreciate much your help with instructions or DIY link on how to replace the condenser cooling fan. (I was wondering if the fan is removed/installed from the top in the engine bay or if it has to be thorough the bottom/underneath the engine.)
Thanks much in advance for any advice!
It looks like its supposed to go up. There are two bolts at the bottom that need to be loosened, and two at the top that must be removed.
Be careful! Unless you disconnect the battery, the fans might theoretically run unexpectedly. Of course, you probably wouldn't be working on an engine hot enough to cause the fans to be needed!
Another note... you might have to remove the radiator fan first. It has only the two bolts at the top holding it in.
Hello liona,
I also need to replace the condenser fan on my 03 Ody.
Did you do yours yet? Do you have any tips? Did you find a good link?
Much thanks,
Jeff
