ok so i installed the hid i got from china, the next day the driver headlight stopped working,then 2 weeks the passenger stoped so i put back the regular lights, anyone have a guide of how to install, i think i might have done it wrong as the headlights where not really secure when the hid were in
I just got the hi/lo h4's from ddm. Make sure you have the positive on battery and a good ground for both. If you dont have hi/lo check the connection to the hid ballast make sure it's on securely or if that doesnt work flip the connector around. They don't tell you that I had to figure that on my own. Good luck. Also make sure you didn't touch the bulb with your fingers. Grease from fingers can cause premature wear m
If they worked initially then the connections were right. Most likely (based on countless HID threads I've seen in the Audi world) the ballasts were junk and stopped working.
It might be a stupid question....But by any chance, Did you touch the bulbs with your bare hands?
