I just installed a valentine one radar detector into my 2006 odyssey touring. Not very difficult. Here were my steps.
1. Remove little light covers and remove the 8mm bolts that hold up the garage door opener overhead console. You can see how I did it in the pics.
2. I then used my meter to find a 12v switched wire. I found a black/yellow wire that went to the mirror that was switched. See pics.
3. I tapped the wire w/ my hard wire kit from valentine. I then drilled a small hole for the ground wire of valentine and attached ground w. small screw. I then tested everything with the meter.
4. You then hide the valentine hard wire kit to the right of hole in the headliner. There was plenty of room to fish the wires and get everything nice pretty.
5. Reinstall the 8mm nuts and you will be all finished.
