1 - 7 of 7 Posts
I am going to replace my lower control arms and outer tie rod ends on 2010 EXL.
Should I shoot some PBlaster penetrating oil on the LCA bolts ahead of time to make removal easier? I was just curious if then there is oil residue on the boss nut threads when I reinstall if that makes it more likely the bolts could loosen even when I torque them properly. Won't matter for the castle nuts as those parts will be new and thus no oil.
I'm probably overthinking but since I am going to use an impact wrench it might be able to free them without oil so if oil has negative effects I just wanted to check first
It can't hurt and will make it easier. Clean the threads before you're reinstall and your good to go.
Sent from my SM-N960U using Tapatalk
If you're worried about oil on the threads, spray them with brake clean before re installing
Sent from my ONEPLUS A5000 using Tapatalk
Discussion Starter #5
Ok I guess I'm not worried then. I just was curious if PBlaster affects the torquing later. I know I wouldn't put antiseize on those bolts but I guess the little bit of oil doesn't make a huge deal
I actually lightly grease my bolts be fore installation. The contact is between the bolt shoulder and the surface that prevents removal. Lightly lubed threads are OK.
Antiseize (oil too) does affect torque settings, be easy on the torque wrench when tightening. I would put antiseize on the bolts since they are exposed and close to the ground.
Make sure the threads are clean!
1 - 7 of 7 Posts
