I noticed yesterday that there is a small gap between the passenger door, and the passenger side sliding door. At mid heigh, by the door handles, the rubber weather seal from the sliding door touches the front door, but towards the top (about 1/2 way up on the window and above) the gap increases a bit and from an angle i can see the white paint of the van in that gap.
On the driver side, it's nice and flush, so no problems there.
Am I being too pick with this?
Thanks,
-Phil
Does water or air get through the area? Take it to a car wash and spray the area manually with a high pressure sprayer. If anything gets through, then you are definitely not too picky and should have the dealer fix it.
that's just the outer seal, between the 2 doors, I assume it's more of a wind / noise feature.
the inner seals seem prefectly fine, we drove through some fairly heavy rain and it held just fine.
