Parts you need:
Original door release actuator
2006-2011 Door release actuator part 72623-SHJ-A21 (drivers side, different number for passenger side)
Tools:
Philips screwdriver, flathead, size 10 ratchet.
I wanted to change out the door release actuator for my 2012 EXL, I have already done the regrease method twice with partially fixed the problem (where you open the door release actuator and grease the gears with lithium grease), but I still got pops and door beeps once in a while (it is worse in winter).
I could not find the part in the Honda catalog. The release actuator is located behind part 13 the latch actuator (the latch actuator is NOT the part you want! I ordered it and was like wtf...)
I went into the dealership and they could not find the part in the catalog either, if someone knows the part number please share it here. I figured the only way to get the part was to order the whole assembly which was $200+ dollars, nah.
I asked the parts guy to bring out the release actuator for the 2006-2011 odyssey, and the parts looked pretty close, so I bought it hoping I could make it work.
2006 Odyssey top, 2011 Odyssey bottom
Open the module by removing the black screw, then take a flathead screwdriver and pry open the case, working your way around the outside.
Everything is the same except the metal part the moved the door mechanism.
Too bad, the metal part is riveted to the case, so no easy way to swap it out. So I decided to use all the new parts in the old bottom housing.
Take out all the gears on the 2011 unit
Remove the motor by prying it up with a screwdriver
Insert the motor from the 2006 unit
Align the part in red and put in the first gear.
Put in all remaining gears from 2006 unit
Put the cover back on, put back screw and put it back in the van.
So far so good for me, if I have the popping come back I will post here.
Tools:
