Sliding doors worked fine this morning when getting in the car but 5 minutes later neither would open. Google led me to pop out the #13 fuse, manually open and close both doors, put fuse back and it almost worked. Now the passenger side door opens normally but the driver side does not. I took it a step further and disconnected the battery but that made no difference. I thought perhaps the computer needed to be reset.
I've opened and closed the fuel door but nothing. I left it open and manually pressed the thingy all the way in but still nothing.
Lock/unlock controls on fob and dash do nothing - the lock-slider on the door doesn't move. The door open button gives the triple beep. Passenger side remains fine.
Now what? (at least i know where the radio reset code is!)
If you look at the date of the post, 7 years with no answer. If you check the poster's profile- last post was 5 years ago. This current post: 1999 Ody sliding door lock issue may help if the driver side sliding door is not working.
