Leaning toward moving the double DIN head unit from my old '05 to the recently bought '08. The fit kits seem to pull up as different parts. Anyone know if it will actually work? Not a big deal if not.
2008+ and -2007 radios have different electrical connectors. All the wires are still there and the same color, so it’s not too complicated to make an adapter but you need a harness cut from the vehicle side. The two steering wheel control wires, if I recall correctly, need to move from one connector in -2007 to a second in the 2008+ ( the connector with the aux in).
Not sure about any nav or RES wires.
Probably simpler for you to just get an 08 to ISO harness and start over, but reuse the mounting from the 05.
I put an 08 stock radio into my 07 EX. The physicals all fit; I should have researched the connectors first.
