1 - 2 of 2 Posts
I just searched Drivers Side Door to see if this topic has come up before, I am sure that it has and I am just not great at finding the right thread yet but here goes.
I have a 1997 Honda Odyssey. The drivers side window does not work essentially. When the button is pushed to operate it the window motor does make a sound but it will neither go up or down. If I press the button to make it go down I can manually force the window down, once it is down if I pull on the button to make the window come up I can manually pull the window up.
Any thoughts on what is going on. The window appears to be in its track and the motor is making noise, but nothing is happening I would appreciate hearing what you all think. Thanks.
The gears may have stripped out or something like that, you'll have to pull the door panel and look.
1 - 2 of 2 Posts
