Try doing the power window control unit reset procedure below. This procedure is listed in TSB 11-018 "Safety Recall: Front Passenger’s Door Window Glass Is Separated From the Regulator" and TSB 11-019 "Safety Recall: Driver’s and Front Passenger’s Door Window Glass Are Separated From the Regulators" in the 2011 TSB thread.
http://www.odyclub.com/forums/54-20...y-technical-service-bulletins.html#post646729
You can also see the power window control unit reset procedure in action by viewing the video below in the Honda Tech2Tech Video thread.
Follow These Steps To Manually Reset That Power Window Control Unit
http://www.odyclub.com/forums/9-pro...ch-videos-service-technicians.html#post714972
POWER WINDOW CONTROL UNIT RESET
NOTE: Do the reset procedure on either or both windows, as needed.
1. Turn the ignition switch to ON (II).
2. Use the power window DOWN switch to move the
power window all the way down.
3. Open the door that you are doing the reset
procedure on.
4. Erase the AUTO UP feature by repeating the
following bullet steps four times:
NOTE: Make sure you do each bullet step within 5
seconds of each other. If you do not, the procedure
will time out, and not work.
• Turn the ignition switch to LOCK (0).
• Push and hold the power window DOWN switch.
• Turn the ignition switch to ON (II).
• Release the power window DOWN switch.
5. Confirm that AUTO UP no longer works. If it does,
repeat step 4.
6. Lower the power window all the way down using
7. Raise the power window all the way up using the
power window UP switch. Hold the switch for
several seconds after the window is closed.
8. Confirm that the power window control unit is reset
by checking the AUTO UP and AUTO DOWN
functions. If the AUTO UP and AUTO DOWN
functions do not work, go to step 1, and repeat the
resetting procedure. Pay close attention to the 5
second time limits in step 4.
If the AUTO UP and AUTO DOWN functions still do
not work, troubleshoot the power window circuit.
