We have an '06 Ody with 202K miles. With the cold wet weather, cranking the van was a little labored. The battery was at 12.1V so I charged it overnight. The starts were quick like usual.
My son drives the van and the other day it was hard to start again. When it finally did, it sputtered a bit. One block down the road, the VSA and ABS lights flashed on. He had the presence of mind to turn back into the parking lot where it completely died.
I went to rescue him with my trusty voltmeter. It read 0.0V with the battery cable attached. When I disconnect the ground cable, the battery read around 4V. Thinking it's a bad battery, I tried to jumpstart it. With the other vehicle running, the voltage drops from 13+V to around 9V and the van doesn't start. Turns out there is a short between the Pos and Neg cables.
I had it towed and am waiting for the Honda dealer to open up tomorrow to see what they say. Does anyone know what type of short could happen that quickly and pull so much power? I've read about the alternator as a possible cause but that thread never followed up with the solution.
Is there hope for a quick fix or do these types of problem cost a lot to troubleshoot?
Thanks for any insights!
