Hey all,
Searched around a bit and couldn't find precisely what I was looking for. Replacing the front engine mount, and decided I had to pull radiator hose - the one from the engine block up to the top of the radiator (it was leaking slow any way). So I cut the top open, realized it was still holding fluid. I drained the radiator itself, and now need to know where the plug for the coolant in the engine is located. I think I found it near the oil filter, but just need to be sure (it seems terrifically inconvenient to drain, as it was create a huge mess it seems (its above the oil pan, near the axle and the O. filter) Don't have the manual to look @ - any advice is appreciated! Thanks!
The drain plug for the block is on the back of the block on the right hand side. It has a nipple where you can attach a rubber hose to divert the coolant into a container.
Hope that helps...
