I have received good help over the years for my 2010 Honda Odyssey from this forum. This is my first time posting. Thank you in in advance for any help that you can provide.
2010 Honda Odyssey Touring
Original Owner
162,000 miles
First off, I have a check charging system light on my dash. I ran tests to confirm that the alternator is indeed bad. I have ordered a Denso alternator from RockAuto. It shows up next week and I will be replacing that.
While I am working on things, I figured I would look into any other fine tuning that I could perform. The engine has a noise while running that I would love to figure out. I will post a short video below. I don't believe that it's the power steering. Although when you turn the wheel, you do hear a very slight whine. I am not sure if that should be addressed or if that is normal. It's not very loud. There definitely seems to be something else going on. I am not sure what it could be.
Could it be the serpentine belt? I don't see any wobble in it. I will investigate it when I remove it to put in the alternator.
Original Owner
162,000 miles
