cybercamp said:
I took my ody to the dealer to check on the engine rattling noise I am hearing whenever I press on the accelerator. I hear it only when the vehicle is moving but not on idle. Their prognosis is that it is just the engine pinging which is normal. And they told me to try to use a medium grade fuel.
Eventhough that engine rattling is normal, its sounds is annoying while I'm driving.
I just wonder if anyone of you experiences this.
How many miles are on it?
A certain MILD amount of pinging is normal if you are not running premium gas. If you hear it frequently and it is loud enough to annoy you then it is likely you have a problem.
The dealer was incorrect in saying the Ody computer was designed for "fast" burning gas.
It was designed to allow you to use lower octane gas without destroying it. It does this just as Wayne described. The ECU (computer) advances the timing to peak efficiency. Depending on many variables, octane being only one of them, the engine will enter pre-ignition which we call pinging or knocking. The knock sensor is a highly sensitive pizeo electric crystal device that tells the ECU to retard the timing to eliminate knocking.
However, it is possible your KS is not sensing engine knock and therefore not telling the ECU to retard. It is also possible that you have a dirty injector or two which are causing limited knock in those cylinders.
Since your Ody is only 3 months old I would find a dealer that knows what they are doing. DON'T talk to a service advisor at the next dealer. Talk to the Lead Technician or Foreman.
If you want an opinion from someone who might actually know you have to get a tech under the hood.
I do know that Honda was able to squeeze about 30HP more into the Ody in part by designing a HIGHLY sensitive knock sensor.
The comment that Ody's don't run better or aren't designed to run on Premium gas is a load of cow manure. I don't care what country they are made for. They are high compression engines that are prone to knocking and therefore will run better on premium gas. Anybody who says different has no idea what they are talking about.
