1 - 10 of 10 Posts
2008 EX. Just changed the oil and noticed a high frequency metalic clicking sound from the engine, louder underneath the engine. It increases with engine speed. The rub is the car has 60,900 miles -just out of warantee. Here is a video of the sound
. It is hard to hear over the other engine noises, it is more noticeable live. It is more noticeable in the video when the engine is reved.
1. Is this noise a problem? It definetely is related to the lower engine and not the valve train.
2. Will Honda cover it even though I am 900 miles out of warantee?
If they will, I will take it to the dealer. If not I will live with it.
Rick
Two things: Thats really close to the end of the warranty. They may cover it. But How did the oil change go? If it started right after that, could you have a problem like a collapsed filter or underfilled oil? If I were you, I'd redo it. Its cheap and easy, plus the dealer wont find some collapsed filter on the engine and immediately blame you and not cover the engine repair (if needed)
Hard to say for sure. One thing I've heard, Honda can and does do goodwill work for customers just outside warranty. Call Honda directly and ask first. My guess based on the sound is a tensioner gone bad. If oil is good (check the level) and all other maintenance have a dealer check it.
1 - 10 of 10 Posts
