2011 Touring elite with 275K miles on it.
I am about to take the Everstart Maxx 24F Walmart battery in for exchange just shy of two years since I exchanged the previous Everstart Maxx 24F at Walmart at 3 years 3 months of age and paid the $72 prorated charge since it was just past the 3 year free replacement. This battery has been going down to under 12 volts overnight for the last week or two, and I could charge it enough to start the Ody, but today before charging I put my battery tester on it and the tester meter showed 12 volts initially but adding the tester load dropped it to 8 volts.
I set my VOM on the DC 10 amp scale and checked between the positive post and the disconnected positive cable and the VOM first showed 2.5 amps then 1.6 amps and then 0.24 amps, taking 3 to 4 seconds between the AMP changes. The DC volt scale the VOM then showed 11.97 volts across the battery terminals. What should the battery drain be in a normal Ody system? I am guessing it should be much less than 0.24 amps.
A little history: The Ody has taken some time to start charging on cold starts for quite awhile now, but once it starts charging it holds at 13.6 to 14 volts all day until the next cold start. Then the "Check Charging System" messaqe might come up a couple of times before it settles down to its normal charging voltage (which I monitor on an UltraGauge).
So...Is my Ody eating batteries because of a high battery drain when turned off? Or did I get another bad battery that has failed in 2 years time?
