Okay everybody after a weekend of testing I can now give you a report on what's not quite working as it should. Don't worry, it's nothing major - it's probably just little things I missed and most likely only need minor adjustment. Maybe some of you can even help me out.
Let's see...
1) A/C - The Auto Climate Control Unit and the A/C button on the NAVI are currently non functional. I am pretty sure it has to do with the missing computer unit near the passenger side airbag. This unit does not come standard on regular EXs.
2) NAVI - The overall Map Guide, GPS and the Searching functions work fine. The only thing that's not is the "Guidence Map". It does not switch over automatically when I reach the blue route (NAVI owners should know what I'm tallking about). I'm guessing this probably has to do with the Computer unit mentioned above.
Also, does anyone know how to erase the previous Personal Pin Numbers. I think the previous owners used them and I can't seem to get into it. Any help would be much appreciated.
3) Panel - The plastic center panel for the slightly sticks out on the bottom right. This is most likely due to the mix-matching screws I used on the radio. It's causing the radio to be slightly off centered - which puts more pressure on one side of the panel than the other. I just have to get some matching screws and it should be okay.
4) Alarm - The alarm is not going off like it should. Maybe some of you with the Honda Alarm can help me with this. There is a grey harness with three wires that not currently connected anything. The wires are Red/Green, Light Blue/Blue, and White/Yellow. Do any of you know where this connects to? (It should be next to a large Lt. Blue Harness)
5) Center Pocket - Those of you with NAVI...there is a green harness behind the lower center pocket. Can you tell me where this connects to also?
That's about it (I think). Hopefully when I get the computer unit everything should be okay. I'll keep you all posted.
Much thanks for all the compliments and support. You guys are great!
-nemogira
P.S. I added some new pics of the installed NAVI to the Gallery.
2000 CCS EX-NAVI
Let's see...
-nemogira
2000 CCS EX-NAVI
