2003 with 58000 miles in 5th gear on and off throttleseems like way to much slop and thunking dropped into D3 seem normal .motor mounts look ok half shafts ok any feedback would be great thanks.
Jack up the front end and rotate each tire back and forth. Block the opposite tire to stop it from rotating. You should be able to feel where the lash is coming from.
Any other symptoms? Noise going around turns?
Excessive slop in 5th gear
Thanks for the reply. I did check the play while up on the stand totaly normal . I test drove a 141000 mile ody it had 75% less slop. And it only does it in 5th gear. dropping into D3 it seems tight I wonder if it has any thing to do with lock up tourqe converter or slippping clutch. I do have egr issue to resolve along with cooler install .I have thank all of you on this site AWSOME work .found the pressure sensor P/S wires broken as reported.What would be great would be a consolidation of tranny issues part # for repair. best cooler,best ATF fluid, kind of a top 10 you guys are great thanks. Dick.
