HI All,
I've been having a problem with my 95. I replaced the exhaust manifold about 3 months ago ( the original was cracked ). A couple of weeks ago the collector pipe worked loose, so I tightened it. 2 days later it was loose again, and I noticed one of the stud holes was stripped. I removed the manifold drilled out the hole for the stud and installed a heli-coil. I re-installed the manifold using lock-tight on the studs and the brass ( bronze?) nuts that connect the collector pipe. 2 days later it was loose again. Has anyone else out there had this problem? Any solutions? I"m out of ideas on this one, and I need this fixed before I go back out to sea next month.
