1 - 8 of 8 Posts
I have a "small" exhaust leak up around the engine. I have not yet determined the source of the leak. I suspect an exhaust component gasket is leaking.
I recall seeing a post here 1-2 years ago about a probable exhaust leak source, but I can't find that thread.
Does anyone recall that thread or have a guess at a likely exhaust leak source at the engine?
Thanks.
Discussion Starter #5
This is the thread I was thinking about; I finally was able to find it.
EGR tube gasket
EGR tube gasket
Those things rust very quickly
The best way I've seen to look for exhaust leaks like that is to tape a shop vac that can blow air, or a leaf blower, to the tail pipe and then spray with soapy water and look for the bubbles. Very primitive but it works very well.
Reactions: thscott
Discussion Starter #8
Follow-up: I had my trusty independent mechanic assess the exhaust leak. He said it is leaking in the flex bellows of what he called the Y-pipe that comes off of the exhaust manifolds and tees into the cat convertor. I believe this is what is referred to on this forum/thread as the J-pipe. (P/N 18210-SHJ-A11)
I have ordered the parts from Majestic (including 3 new gaskets) and should have them next week. Interestingly, I compared prices at Bernardi (which has free shipping) with Majestic. Majestic was significantly cheaper for all the parts ($348 vs $410 for the exhaust pipe) plus total shipping was only &16.
(My hunch/guess about the leak being the EGR tube gasket was apparently wrong.)
1 - 8 of 8 Posts
