Just picked up my '02 SS EXL-RES and man is it the greatest thing since sliced toast.
The RES is amazing.
Thanks you all.
The RES is amazing.
Thanks you all.
<font face="Verdana, Arial" size="2">Originally posted by Lurkerdave:
The RES is amazing.
Thanks you all. </font>
Check to see if your garage door opener is of the 'rolling code' variety. If so, you will need two people to program the homelink - one in the van to push the homelink button and one to push a button on your opener (the motor unit itself, not the remote). I had a tough time getting mine programmed at first, but was finally able to get it to work. The owner's manual covered the steps pretty well, and you may also need to refer to your garage door opener's manual to see if is this type. Good luck.<font face="Verdana, Arial" size="2">Originally posted by I_Love_Ody:
Do you see a red dot on your DVD screen? I see a bright red dot on mine, it is very annoying. I think it is a factory defect.
Also, have you trained your homelink button to learn your garage door codes? Mine just couldn't learn it.</font>
Thanks guys! Yes, the garage door opener is the rolling code type, after I tried many times and finally I called Homelink.<font face="Verdana, Arial" size="2">Originally posted by CJE1110:
Check to see if your garage door opener is of the 'rolling code' variety. </font>
Tony,<font face="Verdana, Arial" size="2">Originally posted by Tony the Tiger:
A stuck pixel is actually a defect on the screen and you should have the dealer replace the screen. Any labtop computer with a deal pixel is usually end up in the refurbished item section of a store.
Tony the Tiger</font>
