1 - 1 of 1 Posts
I found a quick, easy way to fix those annoying twisted seatbelts, you know, when the latching mechanism is turned around, so that when you go to latch it the belt is twisted across your body. Very uncomfortable.
Simply pull on the belt to give it some slack, and then push the latching mechanism up from the "stopper" on the belt. Then, fold the part of the belt immediately under the latching mechanism at a slight angle (45 degrees works fine). Push the latching mechanism over the folded belt and continue "threading" it through until the belt is correctly positioned. Should be a cinch...
Hope this makes some of our ODY drivers a bit safer, and a little less irate...
1 - 1 of 1 Posts
