My floor jack does not have enough lift to use the center jack point (tow hook) as shown in the service manual. Can the frame member which connects the wheel be used to raise that corner and then put the jack stand at the behind the wheels (the same as the scissor jack point)?
Better, if you have Haynes DIY manual, looking on page 10-2, can you identify the jacking points?
Thanks,
- Vikas
There is no safe jack points listed by Honda as safe points other than the four by the wheels and the tiedowns. Get a couple 2x8s and place under the floor jack to get extra lift then plac jack stands under the lift points. Make sure you block the wheels anytime you are jacking and read all the safety notices in the operator manual.
