1 - 2 of 2 Posts
I've done a search, but no one seems to know what the bulb requirement is for the foglights. A place that sells PIAA stuff said that it takes an H3, but it has an extra wire comparing it to the stock bulb. Does anyone know how to make an H3 fit?
H3 bulbs comes with 2 types of pigtails. A round plug in lead and a spade type lead. If you search under H3 at http://store.autotoys.com you can see the different kind of pigtails off the bulbs. The spade type is the most common while the other type is for aftermarket fog and driving lights.
Either way, if the lead does not fit, you can simple wire the positive wire together with the factory lead. On request, if a light has a round lead and you need a spade lead, we will always provide a (pair) free female or male spade to complete the connections depending on which bulb you select.
Here to help
1 - 2 of 2 Posts
