1 - 2 of 2 Posts
I think I want to install the moldings a little higher by an inch or inch and a half. What did you do to keep the template level? Since we cannot make it even with the lower line any longer I am worried I will set the template crooked.
I was thinking of adding a piece of paper or thin cardboard that is an inch or inch and half to the bottom of the template. Other than that I don't know what else would work.
Thanks
Sounds like a good plan. Do the measuring and cutting on a work table in advance, then use your extended template as you normally would. Good luck!
1 - 2 of 2 Posts
