Blower resistor/transistor
I have a 2005 Odyssey EX the front blower stopped working in all speeds including max. The rear fan control works in all speeds but the A/C quit working in the rear. After much checking of all fuses,relays,blower motor,and reading here about this problem I ordered a new blower transistor/ resistor from Autozone. They show 1 for $100 and another $40.
Honda is about $160-170. My friends at Autozone ordered both in for me. The next day they came in and we compared both. The look exactly the same. I bought the one for $40 and now everything works again!!!!
this transistor is monitored by the cars computer and when it see's that the blower is not working it shuts off the A/C.
Not sure why they couldn't just let it run when rear air is requested. Just imagine being on vacation in Florida and no more air. If the rear works, you could survive during the day. However the engineers set it up this way!
my advice, buy the cheap one from Autozone and install it yourself! I am a master ASE mechanic with 20 certificates and can assure you, you can change this yourself with very limited skills. It's under the dash on the passenger side.
If you have the same symptoms ( No blower up front at all including max and no A/C at all ) plus the A/C did work before and rear fan control still works
Dont pay Honda $90-110 to diagnosis it for you, unless spending $300-? Is not a problem for you?
if the $40 part fixes it, then go buy the Honda part, if you are good with soldering iron like these other great post, follow them.
I ordered a spare $40 part and keep it under drivers seat!
i made it 1000 miles to Clearwater beach with no problems!
hope this helps!
