I have always loved EBC "Green Stuff" pads... They likely won't last as long as an "OEM", but the performance difference will be a worthwhile... Better initial bite, better cold temperature performance, and most importantly, less fade at high temps (think loaded van and panic stop situations). I have also had good luck with some Hawk HPS Street Brake Pads. Again, an upgrade from stock performance.
Another recommendation while replacing pads, is a brake fluid flush/bleed. If you are doing it yourself, you have already done most of the work just to service the pads. It's not terribly difficult/expensive, and will be more than worth the effort in pedal feel and
consistent braking/ brake pad wear. I have always been a fan of ATE Super Blue. I use it in my van, my truck, motorcycle, and my old track car...
Don't get me wrong; for normal everyday adventures, the stock brakes on the Oddy are fairly adequate... However, the right (or wrong) combination of variables can put us in perilous situations where every foot of stopping distance matters...
I am obviously the type to justify a small amount more in the initial investment, and also the type who can't leave well enough alone.
In my mind, all it takes is for the brakes to save your bacon just ONCE, and they have MORE than paid for themselves! Paying for some peace of Mind, if you ask me...
Cheers!
Ryan
