Hello Forum, Happy New. I am new to this forum and I have the 2002 Honda Odyssey LX leather/Intertainment Model.
My first question is.... Does anybody know which anti rattle clip type should be installed on the upper and lower outer portion of the front caliper bracket that hold the pads.
I bought my Brake pad kit from a Honda Dealer and the kit comes with clips for all left and right side, inner and outer caliper sides.
I have not check the rear brake so I don't know If it has two types of clip as well.
The Front Anti Rattle Clip have two types, Clip with wider flange and with 90 deg bend at the end. The other has a narrower straight flange (no bent at the end).
According to one site part store picture (http://www.autopartsnetwork.com/cat...ds-1643857/Front_Lower_Outer.html?filter=part name:Disc+Brake+Anti-Rattle+Clip_make:Honda_model:Odyssey_year:2002_)
, a front lower outer clip has a straight flange and no bend but did not show the upper outer portion. I can't find any upper outer clip picture so I cannot tell which clip should go to the upper outer portion. I am hoping that this forum can tell me the correct clip. Thank you
Tedpre
i just did this last weekend for the first time. when you take out the clip notice how they are. of course, the photos here helps a lot. when you install the pads though, make sure you slide the pads in on the top one (with noise indicator) and then bottom will go in easily (i found this after spending 10 min on uncomfortable positions :))
since you bought these from honda, even if you want to you can't screw it up.
