When my front windows are partialy down, and I drive over small sharp bumps the windows rattles. Does anybody know what parts I need to replace to remedy this anoyence?
Thank you.
Same thinng here
I have the same problem, It seems to have developed in the last 2 years.
I'm curious to see if anyone has found a cause/solution.
SportVan
From my understanding is's common problem. The felt in the rails that the window slides in probably needs to be replaced. I wonder if the fixture that attaches to the window also needs to be replaced.
You can see the parts breakdown at Bernardi. It's under "Body/Air Conditioning" and then "Front Door Windows". There's not much to it from what I can see. Maybe a loose fastener or the sash is worn. Mine does the same thing I just don't care enough to take it apart. Close or open the window a bit more calms the issue down.
