on 2002 EX Ody, the fuel and temperature gauge moves intermittently at the same time.
If fuel gauge move to low fuel, then temp moves up higher.
Its hard to tell what's the correct fuel or temp measurement, has anyone see this problem?
What to fix and whats the cost.
Thanks
Potentially a grounding issue on the cluster, or you could just have a really weird coincidental issue with both the fuel sending unit and the coolant temp sensor.
Fuel / Temp Gauge
I have the same year (2002) with the same problem...the fuel gauge reads low and temp reads high. After driving alittle bit, they read correctly. The fuel gauge seems to read low more often than the temp gauge reading high. It started out with just the fuel gauge last year, now both gauges are doing it.
Have you had any luck finding out what is causing this?
The first thing to do is check the battery voltage and connections as well as the charging system. Then as mentioned check all grounds.
