FUEL DOOR help needed!
17K views 5 replies 6 participants last post by  kernel
Depends on if you are having the exact same problem! So your sliding door does not open and neither does your fuel door? :unsure: What have you tried?
In your Owner's Manual it should explain how to use the emergency release for the fuel door if it does not open. Inside the fuel door there are 2 pins or plungers. One opens the fuel door, the other is an interlock that locks the sliding door. One or the other (or both) could be the issue.
  • Helpful
Reactions: 0dyfamily
