Has anyone experienced the light for fuel gauge blinking and then being steady. Thinking circuit board is faulty? thoughts thanks 2003 ex-L
It is not the low fuel light. It is the background dash lite for the fuel gauge that flashes after the headlights have been on for about 3 minutes.
Could be an issue with the bulb illuminating the cluster. May want to consider removing the cluster and replacing that bulb, and any others that may have burned out by now!
I don't know the bulb designations, but there are at least two different bulb sizes.
That is much clearer description of your issue. There are some threads about changing lamps, I am linking one here:
That thread is focused on changing them out to LEDs, but the information is still helpful.
You can use the search. I used the term "instrument cluster" and, if you click advanced search, you can sort of limit the search by selecting 1999-2004 in the drop down menu.
